AutoCAD Crash
AutoCAD Crash
wesbird
AutoCAD Crash
wesbird
Hi
  I'm working a program to create my ribbon on the fly with runtime ribbon api on AutoCAD 2010 which works fine.
  Today AutoCAD 2010 crashed,
  Error message:
    "AutoCAD Error Aborting
    FATAL Error: Unhandled e0434f4dh Exception at 7c812a6bh"
   "AutoCAD Error Aborting    FATAL Error: Unhandled e0434f4dh Exception at 7c812a6bh"
  so I comment the autoload in registry, AutoCAD 2010 still crash. then I start my AutoCAD 2011, close it and start my AutoCAD 2010, 50% will be OK.
  since my dll is not loaded, then where is the problem come from?
  Thank you so much for your time.
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
use this:
Try
''' ALL your code stuff here
Catch ex as SYSTEM.Exception
  msgbox ex.tostring
End Try
put that around your initial command code that starts the whole thing and you may just catch the exception yourself.  Also note the use of SYSTEM.Exception.  When working with AutoCAD, there is also an AutoCAD Exception object that tends to over power the system.exception, so many errors don't get caught.
Good luck.
jvj
