- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've read @_gile's migration guide (thanks to @Jeff_M for the translation) and I've noted @norman.yuan's comments about .NET Framework plugins possibly still working.
I've tried loading our plugin into 2025 and it doesn't work (it doesn't load - no errors, messages or anything).
So, I was just after some confirmation that, this fact that it doesn't load confirms that we will need to migrate to .NET 8? There isn't anything else to change or modify that might allow it to run correctly in 25? I've updated the series Max in the PackageContents xml file to 25.0.
If we do have to migrate, then fine. It's a bit of a pain as we support the current and three previous versions of AutoCAD. I just wanted to make sure there wasn't anything else that we could/should change to potentially make it work in 25 before we go ahead and migrate.
Paul
