AutoCAD 2016 - compatibility
Ertqwa
Ertqwa
Hello forum,
If you create and compile a .NET dll, linked (reference) to dlls from an AutoCAD 2016 version without the service pack 1 or any hotfixes, and you run this .NET dll on an AutoCAD 2016 version that has the service pack 1 and the hotfixes, can this cause compatibly problems (crashes and/or exceptions)?
If you create and compile a .NET dll, linked (reference) to dlls from an AutoCAD 2016 version with the service pack 1 and any hotfixes, and you run this .NET dll on an AutoCAD 2016 version without the service pack 1 and without the hotfixes, can this cause compatibly problems (crashes and/or exceptions)?
If you create and compile a .NET dll on a Windows 10 system, and run it on a Windows 7 system, can this cause compatibly problems (crashes and/or exceptions)? Does a Windows 10 system have other .NET framework libraries then a Windows 7 system?
Thank you for any information on the subject.
_gile
About AutoCAD 2016 SP1, the only example I encountered was about ObjectSnapInfo API.
Gilles Chanteau
GileCAD
GitHub
dgorsman
When building you should link from the SDK rather than an active program install.  Any problems when running will be limited to any quirks and fixes between the updates.
Whether or not it will run on another operating system version will depend on what Framework version it was built to.  That in part depends on the AutoCAD version as well.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Ertqwa
Ty for the answers. Helpfull.
Why should I link to the SDK dlls, rather than an active program install dlls? Aren't they the same dlls?
_gile
From AutoCAD help:
"The DLLs in the ObjectARX SDK are simplified versions of the same files that ship with AutoCAD, as they do not contain dependencies on the AutoCAD user interface. It is recommended that you download and install the ObjectARX SDK, and then reference the DLL files that come with the SDK instead of those that are found in the install directory of AutoCAD or the AutoCAD-based program."
Gilles Chanteau
GileCAD
GitHub
