- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello forum,
If you create and compile a .NET dll, linked (reference) to dlls from an AutoCAD 2016 version without the service pack 1 or any hotfixes, and you run this .NET dll on an AutoCAD 2016 version that has the service pack 1 and the hotfixes, can this cause compatibly problems (crashes and/or exceptions)?
If you create and compile a .NET dll, linked (reference) to dlls from an AutoCAD 2016 version with the service pack 1 and any hotfixes, and you run this .NET dll on an AutoCAD 2016 version without the service pack 1 and without the hotfixes, can this cause compatibly problems (crashes and/or exceptions)?
If you create and compile a .NET dll on a Windows 10 system, and run it on a Windows 7 system, can this cause compatibly problems (crashes and/or exceptions)? Does a Windows 10 system have other .NET framework libraries then a Windows 7 system?
Thank you for any information on the subject.
