AutoCAD 2015 and VB.NET
Having issues with the following line of code:
Dim ThisDrawing As AcadDocument = DocumentExtension.GetAcadDocument(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument)
I have narrowed down the error to the following process:
DocumentExtension.GetAcadDocument()
Can anyone please advise on if they are having the same issues? and how they are getting around it?
I am using Visual Studio 2010, with 2013 dll's (accoremgd, acdbmgd, acmgd, Autodesk.AutoCAD.Interop, and Autodesk.AutoCAD.Interop.Commom)
with a target framework of .NET 4
Any help would be greatly appreciated.
Regards
Lee
_gile
As you're using COM*, I'm afraid you'd have to build a new assembly targeting AutoCAD 2015 libraries and Framework 4.5 which requires Visual Studio 2012.
Another way should be using late binding which avoid referencing the COM libraries.
* most plain .NET applications keep on working on A2015 without any change or need to to recompile.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
how do you mean COM?
_gile
I mean the AutoCAD COM interop API referenced by Autodesk.AutoCAD.Interop, and Autodesk.AutoCAD.Interop.Common.
The COM interface is version dependent
You can read this:
http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-BFFF308E-CC10-4C56-A81E-C15FB300EB70
Gilles Chanteau
GileCAD
GitHub
