AUtoCAD 2013 developer Help
kerry_w_brown
Advisor Advisor
kerry_w_brown
http://docs.autodesk.com/ACD/2013/ENU/index.html
Just did a search for 'generic' filtered by developer.
Of the 50 odd results I found 1 that actually contained the word generic.
For the DevPub Team
Where is the "Comment" link on the Web dased Help ??
Regards
Kerry
PS
and where is the index Tree ?
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
hgasty1001
The new on line help system for 2013 is of no use at all, I can't understand why Autodesk did it this way, the content is not that bad, but you can use it, 'cause you can't find anything without an exhaustive search. If you go to the home page and click on the link to "Learning resources", when you get there ( the "Learning Resources" page) there is no link to 2013 Help, and that's it, end of the road.
Gaston Nunez
DiningPhilosopher
Gaston Nunez
I tried to find a list of all sysem variables, with no luck. Has anyone seen it?
Alfred.NESWADBA
if you have installed the Express-Tools then start command _SYSVDLG and "Save All..."
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
kerry_w_brown
Alfred,
The data is in
C:\Program Files\Autodesk\AutoCAD 2013\Express\sysvdlg.dat
.. but I agree it should be accessable fully from help.
