autocad 2013 CommandMethod assembly reference
Microsoft Visual C# 2010 Express
Trying to create first dll in 2013,
referenced acdbmgd and acmgd (as usual, as in previous versions)
then included:
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
but ...
Error in IDE (Visual C#) when entering: [CommandMethod("TEST")]
Error: CommandMethod could not be found .. are you missing a using directive or an assembly reference
What did I miss?
Thx.
Kevin.
Alfred.NESWADBA
for AutoCAD 2013 you have to reference a third dll by default: AcCoreMgd.dll (to be found in the installation directory of AutoCAD).
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thank You ...
kerry_w_brown
For Reference :
http://through-the-interface.typepad.com/through_the_interface/2012/03/migrating-net-applications-to...
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Excellent - exactly what I needed!
