AutoCAD 2010 Seven 64b read/write Excel/Access
hello
I seek starting from AutoCAD 2010 Seven 64b
in vb.net has
to read and write Excel file (xls)
to read and write Access file (mdb)
have you a solution?
thank you very much
norman.yuan
By "Seven 64b", do you mean 64-bit Windows 7?
Theoretically, What OS is not important, 32-bit 0r 64-bit AutoCAD is. Even you use 64-bit OS, it is still possible to run 32-bit AutoCAD (well, you need a trick to install 32-bit ACad with 64-bit OS, but it is possible).
So, I assume you use AutoCAD 2010 64-bit (then you must use 64-bit OS).
To access data in Excel sheet or Access DB (*.xls, *.xlsx, *.mdb or *.accdb) with 64-bit application (Acad 64-bit), you need 64-bit driver. The good, old Jet Engine is only 32-bit, so you cannot use it. MS released its latest 64-bit Access engine, which you can use to access data in *.xls, *.xlsx, *.mdb, *.accdb without Excel/Access installed, just as you do with before with 32-bit application. The download link is here:
http://www.microsoft.com/downloads/en/details.aspx?displaylang=en&FamilyID=c06b8369-60dd-4b64-a44b-8...
Make sure you download the 64-bit version.
However, there is a big catch you must understand:
Even you use 64-bit OS, it is likely you may still use 32-bit MS office, including 32-bit Excel, and/or 32-bit Access. Yes, there is 64-bit Office since Office 2010. But MS itself recommends using 32-bit Office suite whenever possible. If you do use 32-bit Office, you CANNOT install 64-bit Access database engine! That is, if you have to use 64-bit Access engine to work with AutoCAD (64-bit), then you have to remove 32-bit MS office. If you have to use Office (Who do not?), you will need 64-bit Office. Then, if your Office apps rely on some 32-bit VBA code, then you are toasted...
This may be one of big reason people do not want to move to 64-bit Acad. One option would be to stop accessing data in Excel sheet/Access database directly, instead, moving data to a server-based database, such as SQL Server...
Norman Yuan
Drive CAD With Code
michael_robertson
What we've done is use the Open XML SDK 2.0 for Microsoft Office:
http://msdn.microsoft.com/en-us/library/bb448854.aspx
This lets us use one app for both 32 & 64 bit access to MS Office 2010 formats without depending on the driver, pretty easy to use once you read through the documentation.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
AutoCAD 2010 Windows 7 32 and 64b
Thank you for all its information
If you have an example with code I takes well readily because in vb.net I begin
I think that can be useful has much of anybody who uses AutoCAD in 64b.
Cordially,
Alexandra
