arithmetic operation c#
k005
Advisor Advisor
Message 1 of 11
k005
54.09 m³
25.32 m³
-5.40 m³
How can I get the result of the operation as 74.01?
Replies (10)
Message 2 of 11
ilovejingle
ambiguous question, if you are talking about strings. you need to isolate the number string using a split method, then use double.parse(string) to get the number data. and then do the arithmetic operations.
Message 3 of 11
k005
Yes string value. i am getting this data with Regex. We are already doing the double parse part. transaction is in progress. But it is not falling cumulatively. is adding
Message 4 of 11
ilovejingle
could you please share a short code snippet. otherwise it is very difficult to understand the problem.
Message 5 of 11
k005
Of course I will share. I'm at work now. I'll write again when I get home tonight.
Message 6 of 11
k005
@ilovejingle
 foreach (string record in data)
                    if (rgx.IsMatch(record))
                        foreach (Match m in rgx.Matches(record))
                            if (m.Groups[1].ToString() != "")
                                sum1 += double.Parse(m.Groups[1].ToString());
                            else
                                //toplam20lik += double.Parse(m.Groups[2].ToString());
                    else
                     MessageBox.Show("{0} desene uymayan veri", record);
Message 7 of 11
Norman_Yuan
If your application has to deal with numerical values that come in as text strings, or mixed with non-numerical text string, it is really, really bad programming practice to mix numerical value calculation with text string manipulating/parsing together, whether you use Regular Expression or not.
Norman Yuan
Drive CAD With Code
Message 8 of 11
k005
@Norman_Yuan
So how can I get the negative values for group2 according to this situation?
Message 9 of 11
jtoverka
Message 10 of 11
_gile
See the Regex in this reply.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 11 of 11
k005
I'll get back to you on both issues... Thank you.
