AESWAPBLOCK Replication
08:31 AM
- Mute
- Permalink
- Report
I am looking to replicate a process in the command AESWAPBLOCK. If a user were manually performing this process, they would do the following:
- Open drawing to update
- Type AESWAPBLOCK
- Select "Library Swap"
- Click "OK"
- Change the path
- Check "Include subfolders"
- Click "Active Drawing"
Would you explain the process needed to do this through code? I have very limited experience with programming for AutoCAD, so detail would be appreciated.
Thank you for your time.
