Adding Xdata to a database that's not opened in the editor
amasutti
Message 1 of 9
amasutti
Hi, I'm Using C# to add Xdata to a block reference in a database that's opened in I guess you would call it a Side Data base (not in the drawing Editor). I'm checking for the Registered app and creating it if it doesn't exist. But when it comes to writing the Xdata I get an error EappIdNotFound. I'm Opening the Other drawing database Read-Write. Any Help Would be appreciated. Thanks in advance.
private void PutXdataDate (ObjectId objEntId, string strAppName,string Jdate)
            Database objDB = objEntId.Database;
            Transaction objTrans = objDB.TransactionManager.StartTransaction();
            Entity objEnt = (Entity)objTrans.GetObject(objEntId, OpenMode.ForWrite, false);
            Database db = HostApplicationServices.WorkingDatabase;
            // RegAppTable acRegAppTbl;
            using (Transaction acTrans = db.TransactionManager.StartTransaction())
               var acRegAppTbl = (RegAppTable) acTrans.GetObject(db.RegAppTableId, OpenMode.ForRead);
                if (acRegAppTbl.Has(strAppName) == false)
                    RegAppTableRecord acRegAppTblRec = new RegAppTableRecord();
                    acRegAppTblRec.Name = strAppName;
                    acRegAppTbl.UpgradeOpen();
                    acRegAppTbl.Add(acRegAppTblRec);
                    acTrans.AddNewlyCreatedDBObject(acRegAppTblRec, true);
                    acTrans.Commit();
            using (objTrans)
            bool appFound = false;
            bool found_IO = false;
            bool found_Sig = false;
            if (objEnt.XData != null/* TODO Change to default(_) if this is not a reference type */ )
                bool bChange = false;
                ResultBuffer objResBuf = objEnt.XData;
                ResultBuffer objNewResBuf = new ResultBuffer();
                //TypedValue objTypedVal;
                foreach (TypedValue objTypedVal in objResBuf)
                    if (objTypedVal.TypeCode == 1001)
                        string otypval = (string) objTypedVal.Value;
                        if (otypval.ToString()  == strAppName)
                            appFound = true;
                            bChange = true;
                            objNewResBuf.Add(objTypedVal);
                        else
                            bChange = false;
                    if (bChange == true & objTypedVal.TypeCode != 1001)
                        if (objTypedVal.TypeCode == 1000 & Convert.ToString( objTypedVal.Value).Substring(1, 9).ToUpper() == "Jul_Date=".ToUpper())
                            TypedValue TV = new TypedValue((int) DxfCode.ExtendedDataAsciiString, "Jul_Date=" + Jdate);
                            objNewResBuf.Add(TV);
                            found_IO = true;
                        else
                    if (bChange == false)
                try
                    objEnt.XData = objNewResBuf;
                catch (System.Exception ex)
                   System.Windows.MessageBox.Show (ex.Message);
            ResultBuffer objNewestResBuf = new ResultBuffer();
            if ((found_IO == false | found_Sig == false) & appFound == true)
                    foreach (var objTypedVal in objResBuf)
                            string otypval = (string)objTypedVal.Value;
                                bChange = true;
                                objNewestResBuf.Add(objTypedVal);
                            else
                                bChange = false;
                        if (found_IO == false & objTypedVal.TypeCode != 1001 & bChange == true)
                            TypedValue TV = new TypedValue((int)DxfCode.ExtendedDataAsciiString, "Jul_Date=" + Jdate);
                            objNewestResBuf.Add(TV);
                            found_IO = true;
                        if (bChange == true)
                    try
                        objEnt.XData = objNewestResBuf;
            else if (appFound == false)
                TypedValue TV = new TypedValue((int)DxfCode.ExtendedDataRegAppName, strAppName);
                if (objEnt.XData != null)
                {                    ResultBuffer objResBuf = objEnt.XData;
                try
            objTrans.Commit();
            objTrans.Dispose();
Replies (8)
Message 2 of 9
GeeHaa
Nevermind I figured it out. I was creating the Registered app in the working Database not the Side Database. Instead of DN I created in in objDB. Thanks anyways.
Message 3 of 9
_gile
You add the registered application to the the RegAppTable of the working database (HostApplicationServices.WorkingDatabase). Is it the same as the 'objDb' (objEntId.Database)?
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 4 of 9
_gile
It seems to me the code could be much simpler.
private static void PutXdataDate(ObjectId entId, string appName, string jDate)
    var db = entId.Database;
    using (var tr = new OpenCloseTransaction())
        var regAppTable = (RegAppTable)tr.GetObject(db.RegAppTableId, OpenMode.ForRead);
        if (!regAppTable.Has(appName))
            regAppTable.UpgradeOpen();
            var regApp = new RegAppTableRecord();
            regApp.Name = appName;
            regAppTable.Add(regApp);
            tr.AddNewlyCreatedDBObject(regApp, true);
        var entity = tr.GetObject(entId, OpenMode.ForWrite);
        var xdata = new ResultBuffer(new TypedValue(1001, appName), new TypedValue(1000, "Jul_Date=" + jDate));
        entity.XData = xdata;
        tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Message 5 of 9
GeeHaa
Yes the Working Database is not the same as the Object Database. That was the Problem. But Don't you have to Take care of Other registered apps so you don't overwrite them?
Message 6 of 9
GeeHaa
By the Way I'm amasutti. I don't know why it didn't log me in by my Handle.
Message 7 of 9
GeeHaa
The only other problem I'm having is, I get a file error saving. Can you tell me what I'm doing wrong.
using (Database acCurDB = new Database(false, true))
                        acCurDB.ReadDwgFile(GlobalVariables.listOfFiles[x], FileOpenMode.OpenForReadAndWriteNoShare, true, "");
                        using (Transaction acTrans = acCurDB.TransactionManager.StartTransaction())
                            acCurDB.SaveAs(GlobalVariables.listOfFiles[x], DwgVersion.Newest);
Message 8 of 9
_gile
You can try the code I posted. It will only overwrite the xdata for the specified application (if any).
Gilles Chanteau
GileCAD
GitHub
Message 9 of 9
amasutti
Never mind I figured it out. I needed to use the Overload that saved a Bak file as well.
