addin folder location
Dale.Bartlett
Dale.Bartlett
Hi, Is there any way to return the path to the dll that has been used in Netload the addin application? Dale
______________
Yes, I'm Satoshi.
Alexander.Rivilis
http://adndevblog.typepad.com/autocad/2012/05/listing-loaded-net-assemblyprogram-in-autocad.html
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
chiefbraincloud
Or: System.Windows.Forms.Application.StartupPath
Dale.Bartlett
[System.Windows.Forms.Application.StartupPath] returns the path to acad.exe. That was my first attempt. I have used the previous blog example successfully. Thanks for response. Dale.
______________
Yes, I'm Satoshi.
chiefbraincloud
What about ....ExecutablePath? does it also return the ACAD.exe?
Sorry, I use VB, and My.Application.Info.DirectoryPath returns the Path to my .dll, not the Acad.exe.  The search I did said that Application.StartupPath was the C# equivalent.  Just thought it would be easier than all the code in the DevBlog.
