Add button to object CAD
youssefGC
youssefGC
Hello Forum,
I want to create a code who add a button in the form of an arrow, if the user select this object :
if the user click in this arrow, the object will be rotate 180 degree,
but i don't know a function who add a button with code in selecting object
Thank you.
Norman_Yuan
Well, since you post in programming forum, I assume you are thinking of doing it with .NET code, which you can. But, for your described need, a simple dynamic block would do exactly as required, with a Flip property.
Norman Yuan
Drive CAD With Code
