AcMapMap.GetCurrentMap() failing in AutoCAD 2012
I have a plugin I've written that works fine in AutoCAD Civil 3D 2011. But when I try to run the same plugin in AutOCAD Civil 3D 2012, I get an exception when using the AcMapMap.GetCurrentMap() function.
Here is the unhelpful stack trace:
OSGeo.MapGuide.MgUnclassifiedException: Failed to retrieve message for "MgUnclassifiedException".
   at OSGeo.MapGuide.MapApiPINVOKE.SWIGExceptionHelper.ThrowCustomException(String className, IntPtr cptr)
   at OSGeo.MapGuide.MapApiPINVOKE.AcMapMap_GetCurrentMapInternal()
   at Autodesk.Gis.Map.Platform.AcMapMap.GetCurrentMap()
Does anyone know why this function will not work? I have tried building a separate project which references the 2012 OSGeo DLLs, and I still get the same exception.
-andy
augusto.goncalves
Hi Andy,
I would suggest you repost this question on Civil 3D forum with a small code sample. As you can see, this is a 'unclassified' exception, which usually can have some different reasons...such as not closed resources.
Augusto Goncalves
Autodesk Developer Network
Augusto Goncalves
Twitter @augustomaia
I figured out that some kind of initialization needs to take place before calling GetCurrentMap(). The initialization happens when showing the Task Pane with "mapwspace on ", or with "__MAPSTARTWSPACE". I've added code to run that command when AutoCAD starts and everything is working now.
