AcCoreConsole + OLE Object Printing
Message 1 of 8
Is anyone having success printing OLE objects via AcCoreConsole?  When printing from AutoCAD itself, I'm able to print OLE objects, but when using AcCoreConsole to print, OLE objects do not show up on the print.
Replies (7)
Message 2 of 8
Balaji_Ram
This is a known behavior of AccoreConsole.exe.
Sorry, It cannot print OLE objects at present.
Balaji
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
odurier
I tested on AutoCAD 2014 but it still does not work
Is expected soon?
Many of our customers generates pdf containing OLE objects via accoreconsole.exe
Do you have a solution?
Message 4 of 8
Balaji_Ram
The request is being evaluated by our engineering team and I do not have information on when this might be made available. OLE has dependencies on the window handle and implementing it in AccoreConsole that does not have a UI of its own is likely to be a major implementation. So, this request is likely to be evaluated by our engineering team as a feature request rather than a bug-fix.
Sorry, I do not have a workaround for it.
Balaji
Message 5 of 8
odurier
Thank you for your reply.
But you have more information about the availability of this feature.
This is a standard AutoCAD and our major clients use regularly.
But not able to print the entire layout seems to be a bug anyway.
Message 6 of 8
Neil_Cross
I've just hit this issue and come across the thread.
Might I enquire, given that this functionality is requested and has been absent for years, what exactly have your "engineering team" been doing if not addressing such known limitations?
Whilst internally you may disagree, the overwhelming perception externally is that AutoCAD hasn't changed at all for years and anything added has served no purpose other than unecessarily and pointlessly bloat the software.
What's New 2015, "Geo tagging".
Need I say more.
Your program can't print something which can be placed onto a drawing using core functionality.  Whether you like it or not that's a bug/defect, not a feature request.
Message 7 of 8
odurier
Ok no problem.
Many of our customers makes printing masses treatments on their plans.
We wanted to use the new functionality of the console but we came back because their plans contain many tables excel OLE. This does not work in console mode.
They use OLE mode because it is more convenient for them to manage the Excel sheet (modification, formula etc ...)
Message 8 of 8
MattiasLanzen
Hi wanted to bump this issue and ask if there is any progress/plan to make OLE object printed with AccoreConsole.exe?
