AccessViolationException when trying to open Database using RealDWG
I am trying to create a standalone console application for reading DWG file database using RealDWG.
I have referenced the DLL called "acdbmgd.dll" located in "C:\Program Files\Autodesk\RealDWG 2018".
However, when running this minimal example
using Autodesk.AutoCAD.DatabaseServices;
class Program { static void Main(string[] args) { using (var db = new Database(false, true)) { ... } } }
I get AccessViolationException from the expression
What could be causing this? I have read that one needs to have AutoCAD running when executing external software like this, but that does not apply when using RealDWG, right?
Best regards,
Elias Furenhed
BKSpurgeon
(sorry just realised my solution is wrong)
nevertheless perhaps this might help you:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=770257
also check out the DevTV recording to get a "hello world" example up and running:
http://download.autodesk.com/media/adn/DevTV-Introduction-to-RealDWG-Programming.zip
moogalm
Autodesk Support
Autodesk Support
First please go through the RealDWG examples available with SDK.
For this you need to implement HostApplicationServices.
The minimal sample would be, this a pseudo code.
using Autodesk.AutoCAD.Runtime;
namespace MinimalSample
    class DWGHost : HostApplicationServices
        public override string FindFile(string fileName, Database database, FindFileHint hint)
            return fileName;
        public override void FatalError(string message)
            System.Windows.Forms.MessageBox.Show(message);
	 class Program
            Autodesk.AutoCAD.Runtime.RuntimeSystem.Initialize(new DWGHost(), 1033);
            Database mDatabase = new Database(false, false);
            mDatabase.ReadDwgFile( args[0], FileOpenMode.OpenForReadAndAllShare, true, "");
            using (Transaction oTransaction = mDatabase.TransactionManager.StartTransaction())
                try
                   //process
                catch (System.Exception ex)
                    System.Diagnostics.Trace.WriteLine(ex.Message);
Thanks, I got it working using the sample code above.
Elias
