01:09 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to create a standalone console application for reading DWG file database using RealDWG.
I have referenced the DLL called "acdbmgd.dll" located in "C:\Program Files\Autodesk\RealDWG 2018".
However, when running this minimal example
using Autodesk.AutoCAD.DatabaseServices;
class Program { static void Main(string[] args) { using (var db = new Database(false, true)) { ... } } }
I get AccessViolationException from the expression
What could be causing this? I have read that one needs to have AutoCAD running when executing external software like this, but that does not apply when using RealDWG, right?
Best regards,
Elias Furenhed
