Accessing Duct Fitting Dimension Properties
mhillis
mhillis
Hello all,
Basic question here: Can I access the "Dimensions" portion of the Properties Palette on a Duct Fitting via the .NET API?  If so, what class is that information stored in?
I've scoured around the Entity/Duct Fitting classes with no real avail finding anything.
Thanks!
mhillis
I  believe I've got this figured out now.
Since this object is an MvPart, I can access the information I need via the DataRecord of the object by using the PartManager.GetPartData routines and going through the DataFields there.
I was able to dig this up while doing research and stumbling upon @Keith.Brown 's posts in this thread - http://forums.autodesk.com/t5/autocad-mep-forum/property-set-definition/td-p/538171
A small snippet for anyone who might be reading -
Dim partData as DataRecord = PartManager.GetPartData(member)
Dim field as DataField = partData.FindByName(nameOfField, False)
Dim value as Double = field.ValueDouble
