ACAD 2000 - Point manipulation and Line drawing with VB.Net
I'll just start this out with this... I'm still really new to VB.Net in general, and very new from a "lets use this to do stuff in ACAD" standpoint. Google and the search function here have left me empty handed.
I am trying to get a point from the user, then use and manipulate the X and Y values to draw lines based on those manipulated values. I have gotten as far as the code below, and I'm totally lost when it comes to the syntax of reading and manipulating point values.
How would I turn the code example into something that:
-accepts a point input from user
-adds a variable to the X dimension to create a new point
-draws a line between these 2 points
The project is a bit more complicated than that, but sample code doing what is described above would get me pointed in the right direction.
Thanks in advance!
-Mitch
PS. This is for Mechanical Desktop (ACAD 2000)
Imports AutoCAD
    Private Sub BendLineButton_Click(sender As Object, e As EventArgs) Handles BendLineButton.Click
        Dim AcadApp As AcadApplication
        Try
            AcadApp = GetObject(, "AutoCAD.Application")
            Threading.Thread.Sleep(500)
        Catch ex As Exception
            AcadApp = CreateObject("AutoCAD.Application")
        End Try
        Dim acCurDoc As AcadDocument = AcadApp.ActiveDocument
        acCurDoc.Utility.Prompt("Select start point for bend lines.")
        Dim startpoint As AcadPoint = acCurDoc.Utility.GetPoint()
        'Do Stuff, magical stuff, right here.
    End Sub
ActivistInvestor
See >this topic< in the online docs, and search those same docs for other example code showing what you need to do.
You are trying to assign the result of a call to GetPoint() to an AcadPoint.  An AcadPoint represent a POINT entity in AutoCAD (which you create using the POINT command), it doesn't represent a 3D coordinate. The result of GetPoint() is a variant that contains an array of Double(3) (three doubles representing the X, Y and Z components). That's what you have to assign the result to. From there, it's just a matter of manipulating the array elements as needed, and then using the array in a call to AddLine() or whatever else you want to do.
Thanks in advance!
-Mitch
Imports AutoCAD
        Try
        End Try
    End Sub
Thanks, I was able to get it pretty quickly with your answer.
