about Block reference?
I have two the same the dwg file A and B. I  create a new a single layer in A and  move all entities  to this single layer, then delete all  layers  in A  reserved for the layer and 0 layer . Then open the B, insert the block A to B. Now, everthing is  Ok except the color. In my mind ,  the color of  block A in B  will have the  same color because I set all the entities color bylayer,but it is not.
Why is that and How  can I set the color of  these entities to the  color of the singe layer?
the follow Attachments
first is A, second is B
Does anyone know that?
Alexander.Rivilis
This question is related to programming .NET? If answer is NO - ask this question in the correspondingforum.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
