3D Solid Bounding box
I would to know if there is a way with vb.net for extract the bounding box coordinates of a 3d solid
Alfred.NESWADBA
doesn't that work four you?
Public Overridable ReadOnly Property GeometricExtents As Autodesk.AutoCAD.DatabaseServices.Extents3d
     Member von Autodesk.AutoCAD.DatabaseServices.Entity
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Hi!
Do you have a similar solution for VBA or AutoLisp?
norman.yuan
It is in AutoCAD COM API from the beginning for VBA: Acad3DSolid.GetBoundingBox().
Norman Yuan
Drive CAD With Code
