32bit AND 64bit environment database connectivity
Hi All!
I am interested in getting some dialog going on this subject. Experts, PLEASE chime in!!!
I understand that basic non COM applications compiled in VS using "Any CPU" as the target CPU will run in both 32bit and 64bit. At least in AutoCAD 2011 and above. I also understand that the MS Jet connector will not run in 64bit mode.
So... I (among others) need some advice when it comes to working with database connections in BOTH 32bit and 64bit. I am wondering if we can get some dialog going to provide a complete and accurate solution for the many of us that have (or will have) these requirements.
I have searched but cannot find any complete solutions in the forums. Surely some of you .NET wizards have already resolved this issue!
My personal requirement is this: We are an all 32bit (XP) office with plans to upgrade every machine to 64bit (Win 7) over time. The first 64 bit machine will be rolled out in less than two weeks. It will take us the better part of two years to completely upgrade all of the office machines. Obviously we will need to have custom .NET applications running long before the computer upgrade process is complete.
I have an Access database that I need simple connectivity to inside of AutoCAD. I am basically populating controls with contents from certain fields in the tables of the database. I do not need to make any changes to the database from AutoCAD (at this point in time). The Access database will be used by others outside of AutoCAD. The database will be updated on a regular basis by users outside of AutoCAD, so I am not sure if changing from Access is an option.
So... what is the BEST and most SCALEABLE solution for connecting to a database that will be manipulated by outside users while maintaining the ability to work on both 32bit and 64bit machines?
I have read a few different things in these forums; suggestions of using SQL Express, XML, Access 64bit, etc... But it's all just a bit confusing to me. It would be nice to put this to bed.
TIA!
