2014 conversion
2014 conversion
2014 conversion
I am converting my programs from 2012 to 2014. I am using VB.Net 2010.  I ran into this problem with this code.  I received the error: 'AcadDocument' is not a member of 'Autodesk.AutoCAD.ApplicationServices.Document'.
I put Core after ApplicationServices but that did not fix it.  Any clues?
Imports System Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Public Class myCustomProperties
     Public ReadOnly Property ThisDrawing() As AcadDocument
          Get
               Return Autodesk.AutoCAD. _
               ApplicationServices.Application. _
               DocumentManager.MdiActiveDocument.AcadDocument
          End Get
     End Property
End Class
_gile
Since A 2013, the Document.AcadDocument property have been replaced by the GetAcadDocument() extension method deined in the DocumentExtension module which needs to be imported.
Imports Autodesk.AutoCAD.ApplicationServices.DocumentExtension
          Get
               Return Application.DocumentManager.MdiActiveDocument.GetAcadDocument()
          End Get
     End Property
End Class
Gilles Chanteau
GileCAD
GitHub
