Message 1 of 1
XML properties filename and file path
I'm with a issue on Navisworks. When I've just one .nwc file appended I create a bunch of search sets and export it. When analyzing the exported search set xml file I've noticed that properties filename and filepath was filled with the respective values of what I want. When I've more than 1 .nwc file appended at navisworks, the XML File is losing that two properties reference.Even if I set on Find Items the exactly model that needs to be searched.
I'm working on a large model ( 1GB>). As we don't have the option to work on Navisworks Central Model. I'm breaking the large model into small pieces and making separate sets.
Just a complement of what I said. Some time ago I've tried to create a script where I could do some searchs using parameters and forcing the search to be on the exactly model (using path)that I want to search, but I've seen that it's impossible using Navisworks API.
