Grid Lines not showing in Naviswork Freedom 2024
ronofrioETM4A
Message 1 of 1
ronofrioETM4A
I am making NWD files using Naviswork Manage 2024. The NWD once saved off and opened in Navisworks Freedom 2024 no longer displays the Grid Lines in the project. If the same file is reopened in Manage the grids are present upon opening. I have made sure that Grids are enabled in Freedom. I have also gone and tried to use the grids from all the files present in the NWD. The grids do require some massaging to be present in the Navis Manage, I have to make sure the sectioning is setup correctly before exporting. The sections are set the same in Freedom as they are in Manage. I am unable to find anything in Freedom that would prevent the grids from being present. What could be causing the grids to not show in Freedom vs being shown in Manage?
Replies (0)
