Why is there no CLOSE option in Navisworks 2016?
brendan.henderson
Advisor Advisor
brendan.henderson
{Rant start}
Seems like an overlooked function of being able to Close the current model and open another without having to exit Navisworks and start it again. Needs a close in the bin N menu and an X in the top RH corner of the model, LIKE PRACTICALLY EVERY OTHER SOFTWARE PRODUCT OUT THERE!
{Rant end}
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Patrick_Aps_9121
As one can only open only one NWF at the time, using the NEW button or the open will close your current model and open the other one without the need to re-start Navisworks. So why would you need to use two buttons if one is sufficient.
A Close button would only make sence if Navisworks were able to open several Models simulatainiously, like practically every other software. Then you would need to be able to close only one and leave the others open.
J450NP13
I've never used that exit button.....ever
dgorsman
Occaisonally annoying, but once you get used to using the NEW button its not much different.  Although I've rarely had to close the program to open another file...
There's no zero-document state in Navisworks so like the others have said, closing isn't a valid operation.  The best you can get is a blank, unsaved document.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
bearlE4PNQ
Thanks for being helpful.
I have a similar case where I'm overwriting the file I just exported to Navis, and rather than closing Navis, exporting, reopening Navis, making a "new" blank file helps. Did not think about this process due to habit built from living in the 90's.
No "zero-state" screen in Navis, Thanks!
henrik.pettersson
You don't need to make a new either. Navis doesn't "lock" the file. You can export to the file while having it open in Navis and then just click [refresh]
(I found this thread having your exact thought-process)
Mohamed-Nassar
you can use command New it's the same close in navisworks.
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
