Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Viaduct
3 REPLIES 3
malonicivil1
250 Views, 3 Replies
Viaduct
Hello, good afternoon!
I have to model a viaduct in Revit for which I have a Navisworks file with the model modeled yet, but I don't have plans or anything else. Could someone tell me what data I can get from Navis or what workflow have to follow?. Thank you very much1
3 REPLIES 3
as per your other Question.
You could link a file from Navisworks in Revit, and use it as a reference to create a Revit model
(Note: the linked file its not editable)
In Revit, link to the NWD or NWC file, as follows:
  1. Click Insert tab> Link panel >  Coordination Model.
  2. In the Coordination Model dialog, click Add.
  3. Navigate to the target NWD or NWC file, select it, and click Open.
  4. Click OK.
  5. The linked model displays in the currently active view.
Or you need iConstruct smart dwg exporter (but you will have to pay for this).
https://iconstruct.com/feature/smart-dwg-exporter/
Thank you very much for the answer @alan.johnson7YLND , anyway I have tried with the files that I have for the model and they don´t appear in Revit I don´t know if it is possible that they have any blockage or issue or what could be the reason... I have done a test with another file in the same format .NWD and I can see it in Revit. What can be the problem? thank you very much!!
Rail Community
