V2016 all elements on the same layer highlight in clash test
I have an electrical model in .dwg format that is being used in a clash against other trades.  In each test that includes the suspect .dwg all elements of the same layer are highlighted.
I have read in a previous post that it could be the light source parameter as exported from Revit.  The provider of the file said it do the .dwg file and that if he uploads an nwc it will go away.  I dont think it is a matter of file type, .dwg was the go to file type long before direct nwc uploads.
Does anyone have a suggestion to correct this.
danielkazado
  In the Results tab of Clash Detective , Under Highlighting header in the left try to uncheck the "Highlight All Clashes". This option will either show all clashes or only the selected clash.
Hope Helps....
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
