User Data Tab and Quantification Workbook
Hi all,
I am struggling with following issue:
I created a new user Data Tab to add some new properties to the project model.
Then I created some search sets, that are based on the properties from the “new” Tab.
I wanted to use these search sets in the Quantification-Workbook for the QTO, but NV doesn’t let me to append these search sets into the Workbook.
My guess is that the “new” property tab is a “read and write” Tab.
I was wondering, if you know any way to make the property values again “read only”.
Thanks a lot for your support.
Greetings
Hi @Anonymous if I understood you correctly, you had created user data with New properties and used this property as a criteria to create search sets. But you are not able to add the objects from this search sets into your QTO? Normally it should work just fine as search sets are only selection of objects based on certain properties and that should not restrict you from taking them off to selected items in your quantification workbook.
If this resolves your issue, please click ACCEPT AS SOLUTION to enhance the forum.
Exactly that. I created a new user Data Tab under properties for an element.
No, unfortunatelly it doesn't work for the user defined tabs. It only works for "read only" tabs.
