Render setting question
ahicks_ATS
ahicks_ATS
I'm rendering a project in Navisworks and I'm having some issues with the stereo panorama view.  With the roof turned off you can see but there are shadows on everything.  However, if I turn the roof layer on then I can't see anything because its too dark.  Is there a way to set up some sort of illumination?
Thanks y'all.
Hi @ahicks_ATS,
I am not sure I understand it correctly. Can you explain a little better and post a screenshot?
Best
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
MichaelBussiere2
Thank you for your post.  It looks like you are trying to make a stereo panorama render within Navisworks, but are seeing ill behavior with shadows with respect to the roof object.  There are a lot of possible directions here, so the best bet would be to attach a screen shot of what you see with both the roof turned on and off, and a sample of the file in question.  Please also grab a screen shot of your render settings for review.  Please keep us posted in the community so we can best help in this case moving forward.  Thank you and we look forward to your reply.
For reference with settings,
Stereo Renders: https://knowledge.autodesk.com/support/navisworks-products/learn-explore/caas/CloudHelp/cloudhelp/20...
Working with stereo panoramas in A360: http://docs.autodesk.com/ADSK360/help/ENU/rendering/index.html#!/url=./files/GUID-04ABDDCA-4F5D-4EB7...
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
ahicks_ATS
I submitted it and was told it was fine.  Turns out it was more of a pet project for internal use than a customer request.  Thanks all.
Hi @ahicks_ATS,
glad everything went fine then!
Best of luck!!
Nicola
