Render multiple viewpoints
Using Navisworks Simulate 2011 is there any way to render out more than just 1 viewpoint at a time? I have 190 published files, each file has 12 viewpoints and each viewpoint is rendered out at 1920 x 1080 PNG format so that they can all be brought together once they are rendered to form a type of short movie showing the progress on the project. Thing is, I don't really want to sit here and render out 2280 pictures 1 at a time. That is just madness. So is there a way to render out all viewpoints?
Hi, I had the same issue and found if you create a new animation in the saved viewpoints, drag all your saved views into the animation and then export your animation as if you were going to create a movie file but under the output format you can select JPEG and it will render a sequence of image files.Smiley Very Happy
Your method of dragging all viewpoints into an animation sequence was a good idea, unfortunately all this does is animate the camera from 1 viewpoint to the next so when I go to render out just the image sequence, instead of it rendering only the 12 or so views that I have, it will render hundreds of frames of animation. I may be doing something wrong or there is something you did not explain but as of right now your method does not work for me.
A couple of steps I might have failed to mention are:-
Right click on the animation and select edit, change the duration to the same amount of views that you have ie 12 views = 12 seconds.
Then when rendering the images out make sure that the FPS is set to 1 so you should end up with 12 images 1 per second.
This sometimes creates a couple of extra images but easily deleted.
Hope this helpsSmiley Wink
dgorsman
Nice idea - I think it bears looking into.  🙂
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
I will try this is soon as I am out of my meeting and will let you know how it went. Thanks a lot for your time.
Managed to give it a shot before the meeting. It worked and just like you said there were a couple extra pictures that rendered which is not a big deal. Thanks a lot for your help on this.
