We have Navisworks model data converted from AVEVA Everything 3D /PDMS. I found out that property category display name is different between 2025 and 2024 (See attached picture which compares propery window of same file same modelitem).
Is it intended change or bug?
I'm developing an addin especially for AVEVA model data which uses search API specifying propery category display name. If this change is not bug, I need to modify my addin.
Solved by brett_parkerLUEP7. Go to Solution.
Thanks for posting to the forums.
This change was intentional for Navisworks 2025. Please see release notes here.
This was done because PDMS is an AVEVA product name of which is now end of life for Plant and Marine to follow. E3D Design is the future but we decided to standardise on the company name rather than change to another product name.
Regards
