Problems with dimensions changing values
Good morning,
We have the following issue:
In my .nwf file   the object has certain measurement  example:  2.5 meters   but when i sent this file to a friend for him to use it  the object changed the measurement, on his naviswork manage 2015   shows   6 meters.
We both have the same versión of the software.
Hi @Anonymous,
i think that you should give a try to .Nwd file to be shared with your friend.
Nwf is a container of reference files, and those references are loaded everytime you open (usually it creates the .Nwc file, which is the cache of Navisworks).
One of the reason to explain what is happening to you may be the fact that if the Nwf is loading files locally, your friend will be loading a different Nwc file than the one you have.
I.e. you have file TEST.nwf which contains file SUB.nwc, when you share TEST.nwf with your friend you must also share SUB.nwc, otherwise he will reload it from somewhere, and this will create the difference in measurement.
Try sharing a NWD file, and you will see that it is exactly the same.
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
