Possible to Import Gantt Chart and Assign Tasks to Models Automatically
petestrycharske
Advisor Advisor
petestrycharske
All,
Good afternoon!  Is it possible to import Gantt chart data and automatically assign Part Models to those tasks?  I've not tried this and am not even sure where to start.  Would it require custom API programming to accomplish this goal?  Thanks for your patience as I try to frame out this request.  If you have any questions, please do not hesitate to contact me.  Hope all is well and have a most blessed day!
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
martinTstewart_Adsk
Autodesk Support
Autodesk Support
Hi Pete,
It sounds like you need to use Timeliner. There is some automation to it, but needs to be manually setup and tweaked with TLC to get the results you want.
See
Essential Skills Video - Tour of TimeLiner
TimeLiner User Guide
If my reply was helpful, please "Like" or click the "Accept as Solution" button below (or both).
Martin Stewart
AEC Support Specialist
petestrycharske
Thanks @martinTstewart_Adsk!  I'm somewhat familiar with Timeliner and have manually set up tasks and assigned models to them.  I think my question is more along the lines of Navisworks API.
Would it be possible to have a project file feed in the data into Timeliner and also list the equipment that is tied to each task.  From there I would like to have the program (even custom programming) check each task model and then assign the actual Navisworks model object to the task?  I'm not at all familiar with the Navisworks API and am curious if such a scenario is even possible?  I don't need anyone to do it for me, my client just wants to know if this could be possible.
Hope that helps to clarify my intent and please let me know if you have any questions.  Thanks for your patience, hope all is well and have a most blessed day!
Peace,
Pete
