Pipe fitting parameters not appearing in Navisworks
donied
donied
If I export a Revit file to nwc then append in Navisworks. The properties of a pipe have an element tab with pipe size etc. But the pipe fittings don't have an element tab in the properties so it doesn't display any info such as diameter of the fitting.
Also if I add a shared parameter to the fitting they don't export to Navis.
The same issue happens with duct fittings. anybody know why ?
Hello everyone,
Did someone else encounter this issue? is there a possible solution for this already?
Kind regards!
jrobrador19
Hi there,
I simulated this just now, and it also puzzled me. So in my first try, I also don't see most of the properties of the fitting. All I can see are three tabs (Item, Timeliner and Element ID).
So I looked in the Selection Tree and clicked on the first object above Standard (which is selected when I select the fitting). And now, I can see its properties.
So to be able to do this with selection, just go to your Options > Interface > Selection and change Resolution to First Object.
Upon selecting the fitting, you should be able to select the first object immediately which contains the element properties.
I hope this helps.
Please hit the ACCEPT SOLUTION or LIKE button if my post helped you to solve your problem.
Jerous Obrador
Mechanical Engineer| LinkedIn | Autodesk Certified InstructorRevit Architecture Certified ProfessionalRevit MEP: Mechanical Certified ProfessionalRevit MEP: Electrical Certified ProfessionalInventor Certified Professional | Laguna, Philippines
Win 10 Pro / Dell G7 7590 / i7-9750H / 16GB RAM / NVIDIA GeForce RTX 2060
