override color with search set
is there a way to override the color of an object category by using a search set. essentially what i want to do is right click on lets say pipes and i want to override the color but i dont know if that is possible or not.
USJM05000
If this is a one time event for a very limited number of search sets, then:
1. Select the search set of interest
2. Right click one of the highlighted elements in the model or Selection Tree.
3. Choose Overwrite Item
4. Choose Overwrite Color
5. Select color of interest
If model updates are expected and maintaining a color schema is desired, then utilize the Appearance Profiler tool, located on the Home tab in the Tools panel.  The Appearance Profiler will update color overrides on an unlimited number of search sets and settings can be saved in an external file for reuse on other projects.  Highly recommended.
Joe M in WV
Patrick_Aps_9121
Read the help topic about "appearance profiler"
this automates what you want to do.
ok, i have attached a video. i used the profiler to try and make the color overrides happen but i still cant seem to make it happen. i dont know what im doing wrong.
USJM05000
Color overrides are not visible in a Full Render Mode.  The rendered material takes priority over element color.
On the Viewpoint tab, Render Style panel, change the Mode to Shaded and color overrides should become visible.
Joe M in WV
thank you very much that was annoying me alot! haha.
