From Navisworks 2017 Update 1
...this is new for Navisworks 2017 Update 1. Linked to this issue, we have also added the ‘optimise on load’ option to the Model - > Performance section in global options. It is disabled by default, but when enabled, will perform certain optimisations on load :
- Delete duplicate redlines. All duplicate redlines from existing saved viewpoints will be deleted.
- Optimise saved viewpoint overrides – Some old files could have saved viewpoint overrides with the same appearance stored multiple times. This optimisation removes that redundancy.
- Delete duplicate material attributes – Some files loaded from IFC could have nodes with many 10s or 100s or material attributes on them. This optimisation removes all the extra material attributes from nodes.
- These optimisations should help fix up existing NWD/NWF files that customers have.
