With the 2015 release I was expecting to see the addition of costs (material & labour).
Are they buried deep inside somewhere, or does it still not allow for this?
I understand quantities can be exported and then costed in other applications, but if that needs to be done then the takeoffs might as well be done in the other application too.
Ideally, I was hoping to see material and labour costs from Quantification automatically tally in the Timeliner.
Solved by arief.rahman. Go to Solution.
Hi Chad,
Autodesk aware about your concern to put ability for cost calculation In Navisworks.
For Navisworks 2015 only create quantification for the parts then it should hand over for other 3rd partys for cost estimation.
Please note that Navisworks itsself doesn't keep database with prices. You can give feedback to us about your expectation for Navsiworks on this link below :
