Is there a way to edit the size of the lines in the selection tree, or move the txt in the selection tree to the left as i cant access the Plus symbol to drop down the lists.
Any help would be greatly appreciated.
Solved by fmaZ5SBF. Go to Solution.
I managed to find a solution to this,
I believe it was a screen resolution issue. The fix was to turn enable UI scaling off.
