Hi everyone,
I'm testing an IFC import, and i can't hava any take off from the model because everything is with a "0" value...what am I missing?
Hi @Anonymous,
follow this guide and you should be good:
http://de0qmbqba3hfm.cloudfront.net/attachments/149616/2
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
Thank you Nicola,
I've already tried that, but the problem is that I don't have even the surface or length parameters to export the "xml"
When I open the IFC at Solibri, I find all the parameters in there. It has to be a little thing I can't see...
Kind regards
Hi @Anonymous,
try this my friend:
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Hi Nicola,
I'll try it tomorrow, thanks!,
However, I just tried to open a revit file into NW2016, and to take off the quantities from a simple wall...and it doesn't work either!!!!
In the other hand, I followed a tutorial with a sample file from NW2016, and yeah, that one works fine...so, I actually can't understand what I do wrong.. 😞
I hope to figure it out with the 2017 one and the new IFC Loader..
Kind regards
Hi @Anonymous,
the recognition of measurements is not automatic in Navis.
You need to follow the setup like the tutorial. There are many sites that can guide you through the entire process.
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
