Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
New Server - Update .NWF Source file path
1 REPLY 1
JFN_KSH
487 Views, 1 Reply
We are migrating to a new server (new name, new IP, new all). Our Naviswork models are stored on that server. Is there any way to modify the referenced models FilePath to a new location? I can't seems to modify the saved file path to point to our models n the new server. Do I basically need to create a new Naviswork model?
i hope my bad english is clear enough...
Thanks!
1 REPLY 1
brettgatti
in reply to: JFN_KSH
Do  you use Drive Letters or UNC Pathing?  If you use drive letters and the same letter is used on the new server, then everything should still be found/loaded.
If everything about the path is different then you would have to repath each of the links when you open each of the NWF files.  I do not know of any way to automatically repath but if  you open an NWF file and it can't find any/all links, it will ask for the new path to each item.
If the NWF and each of the NWC files are in the same folder, it should find them regardless of what happens with your network mapping.
Rail Community
