I wanted to know if Navisworks 2015 has the option to generation a report in PDF?
Andrea
Solved by CADTripper. Go to Solution.
Hi andrea.aguilar,
Not at the moment. You cannot write the report to pdf directly from Navisworks but you can write the report to a certain format and open it in MS Excel. From there you can convert it to PDF. Please see below screenshots for your reference :
Image 1 - From Navisworks, Write the Clash Report to MS Excel ( Try the format "HTML (Tabular) )
Image 2 - Clash Report in MS Excel for Conversion to PDF (Note: Open the HTML file from MS Excel Window and not from Windows Explorer)
Thanks Ryan! Yes, I have being using the HTML format and then exporting it to PDF. I'll try to use MS Excel too.
Andrea
ryan, when i report the image don't sit ion the same row as then text so you cant easily see which clash you are viewing ? any idea how to solve?
