Hello @nurul_diyanah
Autodesk Navisworks 2022: from Beginners to Advanced.
Description
Today’s construction professionals rely on Navisworks to provide industry-leading clash detection throughout the construction process. Navisworks is a 3D design review package that used primarily in construction industries to complement 3D design packages (such as #Autodesk #Revit, #AutoCAD, and #MicroStation), #Navisworks allows users to open and combine 3D models, navigate around them in real-time and review the model using a set of tools including comments, redlining, viewpoint, and measurements. A selection of plug-ins enhances the package adding interference detection, 4D time simulation, photorealistic rendering, and PDF-like publishing.
in this course you will learn:
- Combine design and construction data into a single model.
- Identify and resolve clash and interference problems before construction.
- Aggregate data from multiple trades to better control outcomes.
- Animate and interact with model objects for simulation.
- Create schedules directly from project models.
- Import schedules and cost items from external project management applications.
- Measure lines, areas, and counts from #2D sheets or #3D models.
- Create synchronized project views that combine Revit and #AutoCAD files, including geometry, images, and data.
- Export takeoff data to Excel for #analysis.
- How To Manage #4D and #5D For #BIM Projects?
Navisworks Manage 2022
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "
ACCEPT SOLUTION" and consider giving a Kudo.
LinkedInYouTubeUdemy Course
