Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks Search sets
2 REPLIES 2
m.shcheblykin
873 Views, 2 Replies
Hello dear professionals,
please advise how this can be achieved in navis( snap shot is attached)
its a snapshot from navis where you can see grouped different parameters as per schedules in Revit
Pset Railing Pro... its a name of a schedule in a Revit. All the rest it is column headers in a revit schedule. Here people were checking if the column header name is correct ...
Tags (3)
Labels (1)
2 REPLIES 2
hmunsell
in reply to: m.shcheblykin
I had a nice write up on how to do this but lost it 😥. Here is a video showing the process....
 https://autode.sk/2NTPQEk
uses these steps to make as many Selection Sets as you needed.
Update.... right after I posted it, I found the written instructions i wrote....
  • In Navisworks open the Sets window and the Find Items windows
  • In the Find Items window set a search for this
    • You should be able to use this format to find other parameters from your schedule as well.
  • Once set, pick the Find All button in the bottom Left
    • This should select the items based on the criteria specified
  • In the Sets window
  • Pick the Binoculars (Save Search) option
  • The selection set will be created
    • name it as needed
  • once a select set is made, Right Click in the Sets window and pick New Folder
    • the selection set can be moved to the new folder for future use.
Howard Munsell
fpensa
In the selection tree, switch to Properties
Rail Community
