Navisworks Navigation speed
!Dalton_Goodwin!
!Dalton_Goodwin!
I am in a pretty large Navis model 690MB .nwd format. The size shouldnt be a problem because I have larger models. It is scaled correctly.  The walk speed is so fast. I went to the Options - Interface - SteeringWheels - Walk Tool - Walk Speed, where i lowered it to 0.1 and it is still really fast. Almost feels as if it is the same speed as setting it to 10. Also found every other setting where there was a speed setting and it didn't help. I have tried this in 2017 and 2018
Thanks.
!Dalton_Goodwin!
The question is how to slow the speed
BHamlet
Go into the Viewpoint tab on the ribbon.
The Navigate panel has a drop down on the bottom, where you can adjust your linear speed. I usually like to set it a bit lower than you think you need. (Imperial units @ 50' per second)
You can use shift while walking to double the speed when you need a turbo boost!
