Hello guys,
I have a clash report inside of Navisworks, which shows the levels as the first screenshot, but when I export the reports Navisworks decides to export all the clashes in the first level (basement level for example). Before Navisworks works well, are there any export option that i haven't payed attention?
Thank you in advance,
Solved by cmaccari. Go to Solution.
I found it. It was necessary to change de Lode in View > Grids & Levels > All. If you don't change that, in the report will show the level that you choose on this part even if in the clash detection it shows another result.
