How do I change my units from Meters to Feet/Inches in Navisworks Freedom 2012?
Solved by john.lipp. Go to Solution.
Hi tjacque2012,
To change the display units:
1. Click Application Button > Options.
2. In the options editor, expand Interface > Display Units.
3. Select the units you want from the Linear Units dropdown.
Please let us know if this answers your question.
Best regards,
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
This (the change unit application) does not work on my version of Naviworks Freedom.
I have Naviswork Simulate 2011 and the file I have tried to open will only work with Naviswork Freedom 2012.
Is there some update, or service pack for the viewer that I am missing?
Please let me know. Thanks.
Milt a.k.a.-Drafter1981
To All,
Thanks to Lee, (see my othe post) my question was clarified.
It looks as if I was using "File Options" under the Home pulldown tab.
As John Lipp stated if you click the large "N" or the "Navisworks Application" button
there is an "Options" tab, or box, next to the exit program tab.
Thanks again.
Milt (a.k.a. drafter1981)
How can you change the units in the variable to the master file to reimport a new QTO Catalog ? It wont allow me to import a new one with changed units...
