Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks Data Tools - Link Multiple Sheet into one query
7 REPLIES 7
Message 1 of 8
F.Bitetto
664 Views, 7 Replies
Hi, i'm trying to create one query in order to connect multiple excel sheets using only one link.
I have used UNION statement but without success.
SELECT * FROM [Sheet1$] WHERE "CONSTRUCTION PACKAGE" = %prop("ENGINEERING STATUS", "CONSTRUCTION PACKAGE") AND "TITLE NUMBER" = %prop("ENGINEERING STATUS", "TITLE NUMBER ") UNION SELECT * FROM [Sheet2$] WHERE "DRAW ID" = %prop("Element", "DRAW_ID") AND "TITLE NUMBER";
Any suggestions?
7 REPLIES 7
Message 2 of 8
Hello, try this one:
SELECT * FROM [Sheet1$] WHERE "CONSTRUCTION PACKAGE" = %prop("ENGINEERING STATUS", "CONSTRUCTION PACKAGE") AND "TITLE NUMBER" = %prop("ENGINEERING STATUS", "TITLE NUMBER ") ; NAVISWORKS_MAGIC_NEXT_SQL
Message 3 of 8
Hello Sir,
I am try to connect with excel file and use the SQL code as below.
SELECT * FROM [SYS-INFO$] WHERE "S3D"=%prop("Item","WBS") OR "S3D"=%prop("Item","Name")
I want to confirm the sheet name <SYS-INFO> and column A list <S3D>, if value same as <Item-WBS> or <Item-Name>, then could be link the external information and show the information at another tab. But I am not sure why the SQL cannot working; if not use the OR, the link will work!! I still need try to how to solve the question.
thank you!
Message 4 of 8
Hello! Could you attach here or send me somehow your documents? because I did a quick testing and OR is working for me in the similar case...
Message 5 of 8
Dear Sir,
thank your help, i provide my sample nwd and excel file for you confirm.
If only for DwfName or WBS ISO, it could be success, but always fail when use or!!
thank you!
Message 6 of 8
Hello!
To my own regret such connection did not work for me either.
I just may guess that such behaviour is due to the similar internal names of parameters in DWF - SmartPlant3D tab, because OR works when you try match S3D column with several values from Element tab
For example parameters from the Element tab:
Maybe some NAVISWORKS gurus could help us with this one? @Lance.Coffey @lee.mullin
Message 7 of 8
Dear Sir,
Could be provide the SQL OR sample for S3D column with several values from Element tab!!
thank you!
Message 8 of 8
Hello!
Sure, check together with the attached excel's sheet SYS1
SELECT * FROM [SYS1$] WHERE "S3D"=%prop("Element","GUID") OR "S3D"=%prop("Element","Name")
Rail Community
