Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks 2025 Home page
4 REPLIES 4
alan.johnson7YLND
295 Views, 4 Replies
After checking help I have noticed I am missing access to the new home page from an already open file.
I do get the home page when Navisworks first opens but then cant get it back, unless I close NW and reopen.
My Navisworks:
Screen grab from help:
I have just installed the latest update. (2025.3)
Has anyone else had this issue? and know how to fix?
4 REPLIES 4
s.hamel
in reply to: alan.johnson7YLND
When it is missing, ff you hit the little down arrow to the far right of those icons, does it show the home option as checked or unchecked?
Shayne Hamel
Manager, Principal Software Engineering
alan.johnson7YLND
in reply to: s.hamel
As you can see, I have no Home option.
s.hamel
Please try the following:
Close Navisworks
Navigate to %AppData%\Autodesk\Navisworks Manage 2025\
Move the file LastSession.xml to your desktop
Relaunch Navisworks and test if problem still occurs
If problem no longer occurs, please attach the LastSession.xml to your reply here (And then you can just delete it)
Shayne Hamel
alan.johnson7YLND
Ok thank you Shayne that has done the trick, Home page button now visible and working.
File attached.
Rail Community
