Microstation CONNECT to nwc
In the Microstation V8I-version we had the nwexport-possibility (nwexport16.ma), this one doesn't  work in the Microstation CONNECT edition.
What's the trick to export from the CONNECT-edition to navisworks (nwc)?
Thanks!
eric.zhang305
Hello @Anonymous, at this time there is no supported exporter for Mircostation CONNECT, this link will guide you to the exporters that are supported for Navisworks.
Llawrence
Hi Eric,
Who creates the exporters? Autodesk or Bentley?
Lynda
stefansikora
As the exporter-mdl is still not available with Navisworks 2020 i would also like to know who does the programming.
Autodesk or Bentley ?
robin.grafCHSKM
The 2022 and 2021 downloads of the nwc export utility contain 64bit Versions for MicroStation CONNECT Edition finally:
https://www.autodesk.de/products/navisworks/3d-viewers
32bit versions are gone though since 2021 release. Last available version is 2020.
What I can't find is the ability to export nwd just like in the past, it's only nwc now.
